Old 07-27-2013, 06:05 PM   #7 (permalink)
oil pan 4
I located my 3500w block heater and mounted it on the firewall of my suburban (so it cant get lost again).
I obviously have removed the 220v plug and not plumbed coolant into it, I am not going to worry about adding it into the cooling system or wiring it up till later on this year when it starts to cool off.
The coolant will flow out of the 3500w heater and into the heater core if I need to defrost and provide instant heat, if I don't need to defrost then I just leave the heater off and all that heat flows into the block.
I have an electric coolant pump so I can run the 3500w warmer and defrost with out running the engine.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
101Volts (07-01-2020), mikeyjd (06-15-2014)
