Glad to see you found a good motor and things are progressing for you. Since you are getting the pump as well, are you planning to use the pump shaft as part of the new adapter?
I think you should go ahead and build a vacuum tank. It will only be a few dollars and will likely make your pump last longer.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
