Old 07-25-2013, 03:26 PM   #181 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Seriously, zip ties?? Think that'll work? Better than bailing twine and/or duct tape?
Oh yes. Nice thick ones are rated for 50 lbs+ but can handle over 100. Five or six (or ten?) and that motor is going nowhere (except British Columbia).
Old 07-25-2013, 05:11 PM   #182 (permalink)
90 day: 57.73 mpg (US)
How about nine?
EDIT: I have 10 more I can put on. 8 bucks a package -your call! I think it's pretty secure.
Need a final weight? Or can you & the shipper deal with it if it's a bit over?
Old 07-25-2013, 05:59 PM   #183 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
When I've moved motors on pallets like that, I've usually used a ratcheting tie-down strap, like what you use to strap down items in a pickup truck.
If you want something inexpensive/disposable, YES zip-ties work fine, as long as you use the giant industrial ones. There are some VERY large zip-ties out there. In some places, police use them as leg restraints, and then slam the tail of the zip-tie in the back door so the "perp" can't kick the back of the squad-car seats!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 07-25-2013, 09:20 PM   #184 (permalink)
mechman600's Avatar
I'd say it looks good. That perp will stay put for sure.
Can you do a final weight or will that be a pain in the rump for you?
I did a quote for 140 lbs. 150 lbs is the max before it gets REALLY expensive. The motor was 110? I can't see a pump and pallet weighing more than 30-40 lbs, but I 've been wrong before. A lot, actually.
Old 07-26-2013, 11:01 AM   #185 (permalink)
Looks like it's 140 lbs.
Old 07-28-2013, 01:25 AM   #186 (permalink)
mechman600's Avatar
Finally...a half decent video:
Old 07-28-2013, 11:35 AM   #187 (permalink)
Ha! Funny cut to the wee one in the driver's seat. Made me laugh.
Also: was that the vac pump I heard right before the parking brake sound?
Good video!
Old 07-28-2013, 05:15 PM   #188 (permalink)
mechman600's Avatar
Yup...that's it!
Old 07-28-2013, 05:54 PM   #189 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Glad to see you found a good motor and things are progressing for you. Since you are getting the pump as well, are you planning to use the pump shaft as part of the new adapter?
I think you should go ahead and build a vacuum tank. It will only be a few dollars and will likely make your pump last longer.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
The Following User Says Thank You to puddleglum For This Useful Post:
mechman600 (07-28-2013)
Old 07-28-2013, 08:47 PM   #190 (permalink)
mechman600's Avatar
Precisely. My machinist buddy will take part of the shaft and mate it to my clutch center splines. It will be interesting to see how my current adapter is doing after 1200 miles.
I agree 100%. It's on the to do list.
