Old 07-28-2013, 08:47 PM   #190 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by puddleglum View Post
are you planning to use the pump shaft as part of the new adapter?
Precisely. My machinist buddy will take part of the shaft and mate it to my clutch center splines. It will be interesting to see how my current adapter is doing after 1200 miles.
I think you should go ahead and build a vacuum tank. It will only be a few dollars and will likely make your pump last longer.
I agree 100%. It's on the to do list.
