Originally Posted by dcb
"The following words are either very common, too long, or too short and were not included in your search: microSecondsPerGallon"
You can now search on that - or at least you will be able to once the the search tables are re-indexed (may take a little while).
So... try to keep your variable names under
25 chars (Which means you still can't search on antidisestablismentarinism - so don't use that as a var name
