Old 07-31-2013, 01:15 AM   #9 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Originally Posted by baldlobo View Post
engine mounts?
do you still have accesories? are they on an serpentine or v-belt?
do you have all your exhaust hangers and springs?
All mounts are brand new as of a month ago.
Pulley has 3 belts, one for alternator, one for A/C, one for P/S - all attached and working.
Exhaust is on hangars and they look ok. The sound doesn't seem to be coming from any exhaust rattle, but I'll check it out next time I have the car up on ramps for anything touching. About 6 months ago I put a flex pipe in just after the header, the previous owner had just run a straight pipe from header to muffler.
Originally Posted by cbaber View Post
#1 noise sort of sounds like a bearing in the transmission. Possibly the input shaft bearing. I can hear mine under light loads, deceleration, and when the car is in neutral with the clutch out idling.
Come to think of it, I do hear a kinda similar-ish rattling on occasion when at a stoplight, and pushing on the stick lightly makes it go away. How difficult/expensive is an input shaft bearing, and is it safe to let it go for a while?
