Old 08-02-2013, 07:31 AM   #5 (permalink)
josemapiro
Originally Posted by t vago View Post
Also check that your buttons are connected to port c correctly, and that your arduino mega uses the same hardware configuration settings as with the atmega 168/328.
Also, try to correctly spell my name.
Thanks t vago
Ports are correct, I tried with all analog ports and it did not work, I have not connected the wires to the injector and vss, do not know if this is the reason for standing still waiting for some sign. I have not had time to connect to the car, but then you can already shot the doubts.
As for the name I apologize it was carelessness.
Thank you
José Rodrigues
