Old 08-02-2013, 11:46 AM   #5 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
It's fun to get into a completely different car and see what you can squeeze from it. Dumb about the "upgrade" though.
Originally Posted by California98Civic View Post
The transmission also has one of those automatic "manual" functions. On the gear selector is a +/- rocker switch to select gears with. Mainly it is for "sport." But it might help hypermiling if you practice a lot.
Some automatics with paddles, rockers, +/- gates will let you override the default upshift logic to get into higher gears sooner.
Even some CVT's, as I discovered:
EG: http://ecomodder.com/forum/showthrea...rly-21149.html
