Old 08-02-2013, 06:04 PM   #6205 (permalink)
SEBART PL
SEBART PL's Avatar
Ok, I have finished build up new power board, and now I am focusing on over heat protection scripts. I have discovered that my controler read temperature very good but nothing happend when I put sensor to boiling water when I read only on rtd explorer overheat. I thought in that case controler will turn off the contactor for chill to protect transistors.
I have diged in software lines and I could not find any hardware action for high raw_hs_temp; // AD channel 1
on schematic
PC1/ADC1 24 channel
My question is : can we set up maximum working temperature and after reched this turn off contactors ???
I have boiled first set of IRFs so I do not want have this problem again
Please help
(maybe this isue should be published in http://ecomodder.com/forum/showthrea...s-15909-4.html)
