Old 08-03-2013, 04:59 PM   #488 (permalink)
aerohead
n and L
I need some help with the geometry of my jig, so I can determine the actual deflection of each sample from the measurement I got at the end of the bending arm. The two things I know are the radius of the bending arm, and the length of the arc at the free end of the bending arm. I also know the radius at each of the testing positions.
How do I get the included angle of the measurement I took, and then find the arc length i.e. the deflection at the sample?
I need to solve for n and then find the L for the smaller radius at each testing position.
*The circumference is pi X diameter and represents 360-degrees.
*L/C would be the percentage of 360-degrees and spit n out.
* The 'new' circumference at the different station would be pi X D,which would constitute 360-degrees.
*If you measure n there,then L= [[ n/360 X[ ( 2 X radius) X pi]]
