Old 08-03-2013, 05:00 PM   #3 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
You could also look at how clean the inside of the engine is. When's the last time the throttle body and intake manifold were cleaned? Is there sludge on the oil cap? Maybe there is a build up of sludge inside the cylinder or the oil control rings are wearing down. Have you done a compression test? Maybe the compression rings are going bad.
I'm no expert, but with a 20 year old car, I can imagine you could have these issues.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
