Plugs are cheap, sensors are *usually* not. Maybe change the plugs and see what you get out of them. If at the worst, you have a backup set and that way you can rule them (and any coincidences) out.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
