Old 08-05-2013, 02:22 PM   #16 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Originally Posted by rmay635703 View Post
I am guessing frank that if you have a motor that is underpowered enough you could actually "need" the gear.
I rhink that is what cripple_rooster was getting at in the OP and I think that is indeed the future with regards to better FE. The tranny may be more likely to fail with more parts, but that is offset by smaller and less cylinder-ed engines. And with the reviews (read as Consumer Reports) coming back that small engines with turbos isn't really working, more gears is would be the next logical step.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
