Old 08-06-2013, 08:11 AM   #7 (permalink)
josemapiro
Originally Posted by t vago View Post
Can you post the setup procedure? You could also try versio .86, which also had metric functionality.
The connection is this.
The version 0.86 of MPGuino, tried to do the update with the Arduino IDE but the LCD does not show any information, installed Eclipse to do the update but it is the same, and only happens with v0.86 if you use the v0.75, v0.82 metric and the latest version of the OBDuino works, do not know what the problem is.
Thank you for your patience.
José Rodrigues
