Old 08-06-2013, 08:27 AM   #7 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I like the transmission quite a lot. Upshifting early is easy, and so is coasting in neutral. And I am learning to use the instrumentation better. I never did get to pump up the tires before my first distance drive. And now I see the tire pressure reading shows 30psi at 60 degrees ambient air temperature while max sidewall is 51! Or at least that's the max psi recommended on the front driver side tire. Enterprise has at least three different brands of tire on this car.
