Old 08-06-2013, 09:19 AM   #8 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
So, you are saying that the older versions of the MPGuino code work? That it's only the v0.86 code that does not work? I want to make sure that I understand you correctly. Also, I am not completely sure that the MPGuino code was tested to work with an AtMega2560, as in your Arduino Mega board. I am using a AtMega328 based JellyBeanDriver board.
