Old 08-06-2013, 10:59 AM   #9 (permalink)
josemapiro
Originally Posted by t vago View Post
So, you are saying that the older versions of the MPGuino code work? That it's only the v0.86 code that does not work? I want to make sure that I understand you correctly. Also, I am not completely sure that the MPGuino code was tested to work with an AtMega2560, as in your Arduino Mega board. I am using a AtMega328 based JellyBeanDriver board.
That's right, I have not put in the car, but turning on the computer trough USB is what happens.
I bought the Arduino Mega because it wanted to use the OBDuino only after I saw that my ECU has OBDII, now I have to adapt to MPGuino.
Thank you
José Rodrigues
