Old 08-06-2013, 05:03 PM   #11 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
It is possible to confirm whether someone gives to scroll through the menus in MPGuino without having connected the wires of the injector and VSS, thus removing his doubts before placing it in the car.
Thank you
José Rodrigues
Yes, it is not necessary to connect either the fuel injector wire or the VSS wire, to be able to step through the settings. I think you have a hardware initialization issue related to the fact that you're trying to use code on an AtMega2560, that was specifically written fo an AtMega168 (which is pin compatible with the AtMega328).
