Old 08-08-2013, 09:57 PM   #143 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Originally Posted by tjts1 View Post
No you don't. There is no reasonable expectation to allow you block traffic no matter how special you think you are.
Remember this post you made? Reference the bolded words below. Part a clearly states that a person can drive a slow speed, impeding and blocking normal traffic so long as that speed is in compliance with the law. That gives bestclimb the right to drive 55 in a 65, assuming the minimum speed limit is at least 55 mph. You should really give up trying to convince everyone you are right. Clearly, even by your own evidence, you are wrong on the legality of the issue.
V C Section 22400 Minimum Speed Law
(a) No person shall drive upon a highway at such a slow speed as to impede or block the normal and reasonable movement of traffic, unless the reduced speed is necessary for safe operation, because of a grade, or in compliance with law.
No person shall bring a vehicle to a complete stop upon a highway so as to impede or block the normal and reasonable movement of traffic unless the stop is necessary for safe operation or in compliance with law.
(b) Whenever the Department of Transportation determines on the basis of an engineering and traffic survey that slow speeds on any part of a state highway consistently impede the normal and reasonable movement of traffic, the department may determine and declare a minimum speed limit below which no person shall drive a vehicle, except when necessary for safe operation or in compliance with law, when appropriate signs giving notice thereof are erected along the part of the highway for which a minimum speed limit is established.
Subdivision (b) of this section shall apply only to vehicles subject to registration.
Amended Ch. 364, Stats. 1979. Effective January 1, 1980.
1998 Honda Civic HX - My Project Thread
