Originally Posted by tjts1
No you don't. There is no reasonable expectation to allow you block traffic no matter how special you think you are.
I am not blocking traffic, I am traffic, just like every other vehicle on the road. It's got nothing to do with how special I may or may not think I am. You should refrain from Ad hominim as it does not make your point any stronger.
I never said there was a reasonable expectation to block traffic. I said I have a reasonable expectation to be able to drive at some speed between and including the legally defined maximum and minimum speeds. If, like most of the time there is ample opportunity to pass it is a complete non issue. Why do you continue to insist that it is or are you asserting that it is only an issue if there is not opportunity to pass?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
