So basically, if you need more airflow for your engine and don't want to retrofit a larger airbox to accommodate a larger paper filter, then you can use oiled filters, but only if you accept that you're allowing significantly more gunk in your engine and need to clean the filter regularly to maintain peak performance. Myself, I'm sticking with paper!
