Impressive set up. I hope the troubles get cleared soon and easily.
Originally Posted by cbaber
You can't turn the alternator off while the car is running. The switch does nothing. I have to turn the motor off and then I can switch the alternator off. However I can turn the alternator on while the car is running.
That's exactly how mine works in my 1998 Civic DX.
I actually like to keep a spare tire in there just in case. You won't need it until you need it, but I would rather be able to limp to the nearest tire place than call a tow truck or leave the car to go repair the tire.
I have that emergency flat-tire-filler-spray-stuff-in-a-can. Lighter and smaller than the tire.
-james
