Old 08-14-2013, 02:24 AM   #105 (permalink)
serialk11r
How is iron inferior to aluminum? As far as I can tell, the only advantage aluminum has over iron is weight savings.
How much weight does the typical aluminum block save over the iron counterpart?
Thermal conductivity, more controllable cylinder bore temperature, potentially less knock. Aluminum shortblock vs. iron probably saves like 30% of an engine's weight? Aka usually >100 lbs.
