Old 08-16-2013, 03:33 PM   #17 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Originally Posted by some_other_dave View Post
Don't use a 3/8" socket on the crank pulley bolt. You need a 1/2" drive socket. And a good way to hold the crank from moving, like a screwdriver jammed in the flywheel teeth or some such.
Or use a really good air hammer/impact wrench on it. That puppy is on TIGHT!
-soD
Yeah, pulley bolt came out with a proper socket, had to remove it in order to get to the belt. I bought the proper tool for holding the crank still when I ordered the new belt (and it got here first), but I still ended up standing on the end of my 30" breaker bar before it budged. New belt should be here tomorrow.
