Old 08-16-2013, 09:15 PM   #25 (permalink)
freebeard
euromodder -- Front? It went thataway <==>
Yes, of course. The drawing was made for a guy with a pickup truck and I didn't want to overload him. Both sides, entry and departure angles per Thee Template.
I was mainly concerned about the construction from two U-shapes, with the belting unconstrained at it's upper end center.
What I learned last weekend is that the outer half of the spat may be redundant. The rule at Bonneville is [apparently] fences need to be longitudinal to the direction of travel. None the less, I saw examples that hug the tire on the inside and angle across the width of the tread. Like so...
Vekke (08-18-2013)
