Old 08-18-2013, 05:01 AM   #11 (permalink)
freebeard
Side gusts are apparently a problem. They had track #3 shut down for high winds while track #4, right beside it but on a different azimuth was good to go.
What do you make of this?
An underslung frame, and that cast aluminum plate has a hinge at the bottom and the simplest possible choke cable release at the top. It looks like a parachute on the back of a Ford 9" rear end.
