Old 08-19-2013, 06:53 PM   #103 (permalink)
IamIan
IamIan's Avatar
Originally Posted by sendler View Post
Saying that you are running the speed limit doesn't tell us anything. 50 mph is pretty slow regardless of what the speed limit is compared to interstate highway driving.
I guess that is where you and I disagree ... on the use of the phrase 'pretty slow'.
For me:
50MPH is not pretty slow in a 25MPH posted speed limit zone ... or a grocery store parking lot ... if anything it is 'way too fast' for either of those ... etc ... but by all means , tell the police officer giving you the ticket it was 'pretty slow' ... For me ... 50MPH is 'pretty slow' in areas where the posted speed limit is ~60MPH or above... I would technically call it 'pretty slow' in a 56mph or above ... but it jumps from 55 to 60.
That is why for me my speed in relation to the posted speed limit , completely determines weather it is 'pretty slow' or not... if you are not using that phrase the same way ... if anything and everything less than 65mph is 'pretty slow' no matter where you are or what the posted speed limit is ... than you just aren't using the phrase to mean the same thing I am.
Without something like a posted speed limit for a reference ... any speed can be 'pretty slow' ... and thus the phrase itself is meaningless ... 100 mph is 'pretty slow' compared to the speed of sound ... the speed of sound it 'pretty slow' compared to the speed of light ... the speed of light is 'pretty slow compared to Warp 2 ... Warp 2 is 'pretty slow' compared to a worm hole ... etc... etc... there is always a faster speed and any speed would be 'pretty slow'.
That is why I was wondering about what your average speed was in order to get results that are so far above the average for the Gen1 Insight which is about 60 mpgUS.
And that makes sense ... which is why I posted MetroMPG's MPG vs MPH chart ... which you immediately rejected ... Forgetting for a moment what you expect the MPG vs MPH to be ... what about MetroMPG's testing method do you disagree with? ... if there is no serious flaw in the testing method ... then the data is the data ... no matter how different it might be from what was expected.
I get above the EPA ~60 MPG average because I drive more efficiently than the EPA cycle ... that's all their is to it.
I don't draft ... although that can help others who do it.
I drive a Manual Transmission.
I do drive in Lean Burn as much as is reasonably possible.
I do conservation of momentum.
I predict other drivers ahead of me.
I make an effort to avoid lower efficiency BSFC conditions for the ICE.
I have a few minor mods: MIMA, FAS, OBDIIC&C
I try to avoid driving more than 5 mph over the speed limit.
The phrase ... YMMV ... 100% applies ... even with my same driving methods ... MPG at the same MPH will still vary at different temperatures ... head wind or tail wind ... up hill vs down hill ... rain vs not ... steady speed vs stop start ... etc ... etc... I'm not saying 70MPG is possible in any conditions ... that would be wrong ... but it is possible that and better has been done by people ... for whole tanks of gas ... at highway speeds ... for over 120,000 miles ... .etc.
