Old 08-20-2013, 08:53 PM   #26 (permalink)
RobertISaar
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
Originally Posted by ksa8907 View Post
Perhaps I don't understand how the system is wired. I'm assuming it is electronic ignition timing from what I'm hearing. Cant you just bridge the signal wires from one coil and feed them to the other?
there is no need to. they already operate in that fashion at all times except for when cranking the engine.
based on both factory docs and what has been tested, both coils are operated at the same time for a given cylinder.
both 1/4 coils charge and fire
both 2/3 coils charge and fire
that's how the factory doc is implying it and it would appear that is exactly how they function based on the timing light.
