Old 08-20-2013, 06:10 PM   #21 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
also, in case you've never done so, unplug either coil pack's main connector. one will cause the engine to never fire, the other will allow it to idle. the "no fire" on one is due to only one pack being used while cranking, it comes online once the engine is running.
anyways, with only one coilpack alive, you'll make about enough power to hit 40MPH and that's it. this system was designed around both being functional, if not, problems occur.
Old 08-20-2013, 06:15 PM   #22 (permalink)
Originally Posted by R.W.Dale View Post
I just an a couple tests.
No1 on the rear coil (run side) is firing on the mark with about 20 degrees of advance dialed in
On the wasted spark coil number 1 or 4 is also on the mark with the same advance dialed in
Now what I need to determine next is are the two #1's firing together or are they firing 180* out of phase
you answered your own question. if it were firing 180* out, then your timing light would fire with the timing mark on the other side.
Old 08-20-2013, 06:41 PM   #23 (permalink)
LE Camry - '03 toyota camry LE
90 day: 32.63 mpg (US)
It would appear as though your correct. Complex stuff aside when I think about it swapping 1-4 and 2-3 would do absolutely nothing because of one of the fundamental ways DIS systems work.
Focus on 1-4 here
As you note they're on the same individual coil. When that coil fires it naturally fires towards the spark plug experiencing the highest pressure through the head across the gap on the opposite plug (weaker this time) and back to the coil. Then it swaps direction on the next firing because a different coil is under compression. Which cylinder is under compression determines which fires not whatever plug wire is on what end of that coil.
After pouring over this and with your input its my belief that swapping 1/4 and 2/3 on the passengers side coil (or any coil) will do absolutely NOTHING good or bad. That coil will still fire the same plug at the same time it'll just do so on the opposite terminal
Too much junk to list. From a 10mpg caddy limo to a 5 speed Saturn
Old 08-20-2013, 06:49 PM   #24 (permalink)
depending on how the wires are swapped around, yes. if you swapped the wires around so that one coil fired both plugs on a cylinder, then problems can start popping up, since instead of having two different coils providing a strong + waste spark, you'll have the coil alternating between firing two strong plugs and two waste plugs, which will certainly show you if a coil is weak, since it will do just fine for the waste events but fall short for the strong events.
Ford set it up in what i would consider an optimal arrangement on all fronts. i don't see any possible advantages to firing it the way some have suggested in the past.
Old 08-20-2013, 08:45 PM   #25 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Perhaps I don't understand how the system is wired. I'm assuming it is electronic ignition timing from what I'm hearing. Cant you just bridge the signal wires from one coil and feed them to the other?
Old 08-20-2013, 08:53 PM   #26 (permalink)
there is no need to. they already operate in that fashion at all times except for when cranking the engine.
based on both factory docs and what has been tested, both coils are operated at the same time for a given cylinder.
both 1/4 coils charge and fire
both 2/3 coils charge and fire
that's how the factory doc is implying it and it would appear that is exactly how they function based on the timing light.
Old 08-21-2013, 03:45 AM   #27 (permalink)
The PRC.
Just popping in to wish good luck and to observe - also trying to ecodrive an auto...
Old 08-22-2013, 03:11 AM   #28 (permalink)
There may be some truth in the origin of swapping the wire leads from 1-4 and 4-1, and 2-3 and 3-2. (That is what is being discussed isn't it? It got a bit hazy for me.)
Any waste spark ignition system will be firing one of the spark plugs in each pair from tip to ground and the other from ground to tip. The spark plugs erode accordingly.
It is easier to fire a spark from a sharp point or edge, such as from a nice square spark plug tip, than from a rounded, eroded surface.
If you have car with spark plugs near the end of their useful life and swap the leads, the direction in which they fire is reversed and there are fresh edges for the spark to jump from, improving the ignition.
Maybe not, but does it make sense?
Old 08-22-2013, 11:19 AM   #29 (permalink)
the spark likes a sharp edge on both sides of the gap.
it MIGHT have some effect, but i'd rather just change the plugs out.
Old 08-22-2013, 08:55 PM   #30 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Welcome aboard, fellow Mustang owner! I know from my own experience that it's possible to average over 30 MPG commuting with a 4 liter V-6 S-197 (2005-2009) Mustang. The mods that made the major differences in fuel economy were "adjusting the nut behind the steering wheel" and adjusting my commute route to eliminate driving @ 75 MPH (or driving @ 65 MPH in the 75 MPH speed limit areas). I live in northern Arizona - rarely need A/C unless I have a passenger.
Best of luck with your project.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
