Old 08-23-2013, 12:32 AM   #111 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Enough with the theories, this is credible evidence. You may need to zoom in to read the graphs. Press CTRL and the + button to zoom in, and CTRL and - key to zoom out.
Barry's Tire Tech
I'll highlight a few important points.
I hope you noticed how flat the wear index is for the radial tire. I interpret this to mean that conducting a "chalk test" is not a good way to determine what the best pressure is for wear. Put another way - Radial tires are pretty insensitive to pressure when it comes to wear pattern.
The first parameter they looked at was cornering coefficient - and all that yielded was that increasing pressure resulted in a quicker responding tire
Braking Traction: Dry traction is unaffected by inflation pressure, and while wet traction is improved, the effect is small.
Dynamic Bruise: More pressure is worse.
1998 Honda Civic HX - My Project Thread
