Old 08-24-2013, 01:51 AM   #11 (permalink)
RustyLugNut
Check the specs for the Mosfet soldering.
Originally Posted by trekmandude View Post
VR1 was set to ~half. after the most recent MOSFET fried, I turned it CCW, but haven't tried it since.... maybe I will when I get home from work tonight!!
ya, it does take a lot of heat to get the solder to wick in. I used a heat gun and a high power soldering iron.
Follow them as closely as you can. Too much heat for too long and you will have compromised it's functionality. If the design is proven and the parts are good, all that is left is your assembly. Double check your assembly.
