Old 08-24-2013, 12:51 AM   #11 (permalink)
Check the specs for the Mosfet soldering.
Originally Posted by trekmandude View Post
VR1 was set to ~half. after the most recent MOSFET fried, I turned it CCW, but haven't tried it since.... maybe I will when I get home from work tonight!!
ya, it does take a lot of heat to get the solder to wick in. I used a heat gun and a high power soldering iron.
Follow them as closely as you can. Too much heat for too long and you will have compromised it's functionality. If the design is proven and the parts are good, all that is left is your assembly. Double check your assembly.
Old 08-25-2013, 02:01 PM   #12 (permalink)
yes, the design looks good and sounds like most people are having a lot of success. I'm not questioning the design, I am questioning my assembly, set up, or settings... (I'm the lone idiot here)
I have turned the current limit all the way down....unless CCW on VR1 is all the way up.
Old 08-29-2013, 07:04 PM   #13 (permalink)
Joe
Any pictures of before or after?
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 09-09-2013, 01:04 PM   #14 (permalink)
I have been driving the car with the current limit turned down. no problems so far! drives great!
unfortunately, I did not take any pics before installation. I will take a couple pics when I get home and find my camera...
