Old 08-25-2013, 01:21 PM   #14 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by ksa8907 View Post
Yes, but a larger displacement 4 cyl. diesel would do fine in a half ton truck. My point is I think its overkill to put that large of a diesel in a half ton truck. The only time you would need more power than the gas engine can make is when you have already grossly overloaded the truck.
It'll probably make one hell of a sport truck though.
I believe the current standard gas engine in the Titan is a 5.6 liter V8 rated at 317 HP and 385 lb ft. So the diesel power rating will probably be pretty much the same but the torque rating will be quite a bit higher.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
