Old 08-27-2013, 05:33 PM   #77 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by TurnNBurn View Post
Okay, and the throttle is good for the alltrax 7245 up to 72v?
http://www.alltraxinc.com/Products_AXE.html
Your alltrax controller should have 4 flat spade terminals and it should have a label stating that it's programed for a 0-5k throttle, if it's lacking the label then check that it has the 4 small 1/4" wide connections, if it's an AXE controller then you can reprogram it to work as a 2 wire 0-5k or a 3 wire where the 3rd wire is Battery + (I think), if instead of having flat connections it's 1/16" round pins then it's an inductive throttle, I've never worked with inductive throttles.
Flat connections for resistive 0-5k throttles like the Magura twist throttle.
Round connections for inductive throttles.
