Originally Posted by Ryland
Your alltrax controller should have 4 flat spade terminals and it should have a label stating that it's programed for a 0-5k throttle, if it's lacking the label then check that it has the 4 small 1/4" wide connections, if it's an AXE controller then you can reprogram it to work as a 2 wire 0-5k or a 3 wire where the 3rd wire is Battery + (I think), if instead of having flat connections it's 1/16" round pins then it's an inductive throttle, I've never worked with inductive throttles.
It does have the 4 flat terminals. I remember those. I haven't looked into wiring most of the stuff yet. So the magura grip will work just fine for my needs. I'm going to order one of those while the motor is being shipped.
