Originally Posted by Geocritter
BTW are you a rock climber? I tried it about 15 years ago as part of my middle-age crazy period. After two years of climbing I decided that even if I was 30 years younger I'd still be lousy at it.
No the handle comes from flying, each wing has specific airspeeds that results in the best rate or angle of climb.
The Guino is pretty easy to install, 4 wires. one to an always hot 12v source, one to ground, one to the fuel injector signal wire, and one to the vehicle speed sensor wire. If you search the forum you may find someone who has installed on on a similar era ford truck or van and that may put you in the right direction.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
