Old 08-28-2013, 11:09 AM   #80 (permalink)
TurnNBurn
Originally Posted by Ryland View Post
http://www.alltraxinc.com/files/Doc1...e-wire-dia.pdf
It's really simple for a motorcycle, you have the key switch, contactor, throttle, a couple of diodes, a couple of fuses, a resister and a controller.
Uggg. Yesterday was a rough day. I was confused a bit by the 5k ohms and thought it wouldnt work.....then I realized that had absolutely nothing to do with the controller or the batteries. I need more sleep.
Ordered the motor, throttle, and once those are in I'll order the batteries. Still shopping around for a good supplier.
This will be my first electrical project. I've had a lot of experience with fixing things mechanically (transmissions, engines, etc...) but this will be my first wiring project. What gauge of wiring would you guys recommend for the main battery setup? (wiring batteries, controller, and throttle)
