have you thought about laying actual fiberglass over this using it as a positive mold?
Putting Aluminum foil over it first that way you don't actually ruin anything at all and releases easily, you could complete it for about $100 or less...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
