Old 09-23-2012, 04:25 PM   #11 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Just curious what your previous mpg figure was for comparison sake?
You mentioned high speed.... 70mph, 75mph???
Thanks, nice work!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 09-23-2012, 06:44 PM   #12 (permalink)
Honda modder
civruck - '88 Honda civic lx
Yes, 75 to 80 tested to 90.
Old 09-23-2012, 11:48 PM   #13 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
not many use a manometer . that build looks real nice I'll look for you next time I'm on 166 headed out of town. and I'm going to use the RNfiberglass I've got my ribs cut just need more time in a day
Old 09-23-2012, 11:59 PM   #14 (permalink)
Honda modder
Just make certain that no moisture gets under the RNfiberglass or it will delaminate.
So, paint all your edges thoroughly with the latex paint. Then I have found it to
be very durable.
Old 08-29-2013, 08:17 PM   #15 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
have you thought about laying actual fiberglass over this using it as a positive mold?
Putting Aluminum foil over it first that way you don't actually ruin anything at all and releases easily, you could complete it for about $100 or less...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 08-30-2013, 02:24 PM   #16 (permalink)
manometer
Originally Posted by darrylrobida View Post
3mpg is an estimate. That figure is for high speed freeway driveing. As to how I measure MPG. I've tried computers and Mpguino and have come to a conclusion.
I will use a graduated cylinder for gas volume and a calibrated rear trailing bicycle wheel.
Also, why doesn't anybody blog about using a manometer to measure vacuum behind the vehicle?
The vehicles near wake can be an extremely complex blend of eddies,full-blown turbulence,and upper and lower corner vortices.
You would need to do a very accurate 10 or 20-position pitot-tube traverse of the near wake,average all the pressures,then see if any one specific sampling position happened to represent the mean average pressure.Then from there on out,do all your sampling from only that location.
Short of that,we'd be guessing as to the actual wake conditions back there.
mikeyjd (03-06-2014)
Old 09-02-2013, 09:39 AM   #17 (permalink)
Honda modder
Mr. Aerohead, Thanks for the great info about manometer usage as applies to
vehicle wake.
Next:
I have plans to build a surface mount radiator, thus eliminating all front air intake.
I would like your opinion about how much this might improve the aerodynamics.
Old 09-02-2013, 05:05 PM   #18 (permalink)
What are your opinions about whether there is downforce from the front increasing drag?
I try to be helpful. I'm not an expert.
