Old 08-30-2013, 01:19 PM   #40 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by cbaber View Post
tonight I measured out my 50 mile commute home, accounting for elevation changes. It came out to 49.9 miles. My ODO read 47.5 miles. 2.4 miles difference is 5%! If you look at my current highest tank of about 46 MPG and apply the correct miles traveled, it brings it up past 48 MPG!!
You might go back and correct your earlier entries like Old Mech says. I did not, because I only became aware of the under count my tires were producing after I swapped the transmission. But ever since the swap I have applied a 1.055 multiplier to the stock odometer reading. That's 5.5%, which I confirmed repeatedly using a GPS and ridewithgps.com ... when I get new tires this fall and switch my front wheels to my 13" VX wheels (like the back ones currently are) I will re-calibrate.
