Old 08-30-2013, 04:18 PM   #67 (permalink)
aerohead
determine
Originally Posted by Old Mechanic View Post
To determine if fuel pressure is your problem, install a t fitting and a pressure gauge.
To determine if ignition is your problem, wrap a piece of wire (insulated) around a plug wire, then run it to your antenna (regardless of configuration). Turn the radio to AM and you will get severe static in the radio. When the ignition dies the static will decrease greatly or stop altogether.
regards
Mech
Thanks Mech!
When I saw Marvin(the mechanic) last,he achieved spark and was intending to bypass any relays and hot-wire the pump and do exactly as you suggested.
He was sitting on the shop floor with the tank out of a Mercury Cougar undergoing the same process and had just discovered that the new O'Reilly' electric pump was FUBAR and he'd have to go to Ford for a real OEM part.
A Volvo wagon was also entertaining him with some fuel system wiring loom antics.
It's been awfully hot and I need to check just to see if he's okay health-wise.
I got heat-drunk the other day working on a roof and had to quit at 3:00 PM.
The two of us are the same age.No spring chickens.
