Ethanol does produce less energy per gallon, but FE does not go down proportionally, torque does. So, to get the same torque you'll open the throttle more, reducing pumping losses (improved volumetric efficiency). Depending on the engine, gearing, and load you may improve your overall efficiency faster by reducing those pumping losses faster than you're losing out due to the lower energy content.
