Old 08-31-2013, 03:32 PM   #65 (permalink)
RedDevil
90 day: 55.57 mpg (US)
I do not have an ABA test result, and I will never have it. I will not remove the springs as I feel they make for a more predictable brake behaviour.
I do have some kind of AB data though; the 'hot brake' test.
When I just got my car I was glad with the FE, but not really impressed. There seemed to be bad days; low wind, reasonable temperature, moderate driving, but not able to get the same figures as the previous day under worse circumstances.
After one of these days I saw the air vibrate in one of the wheel wells. Heat! Sure enough, the disk was almost too hot to touch. But only on that wheel; the others were lukewarm.
After that I regularly check brake temp after a drive, esp. when FE is less than hoped for. And sure enough, I had several hot brakes in the course of half a year; usually the left front but sometimes another, even the smaller rear brakes take turns.
Now that I have the extra springs up front I only have the occasional hot rear disk.
No hard numbers; the decision to check them is subjective after all. But a night and day difference for this one aspect.
