Old 09-03-2013, 08:32 PM   #18 (permalink)
NeilBlanchard
Originally Posted by Vekke View Post
Yes that is good sheet but I should have looked that before made my measurements... Now I have to make new tests as I did not measure 70 seconds of data.
Also I have to try find better place to measure. its difficult in Finland to find level road that is long enough for this purpose.
That is the challenge I had hear in New England, as well - straight, flat and level roads with little traffic where you can turn around at either end to make 3 runs in each direction, are very hard to find. Do it at night would help on the traffic front, at least.
And video recording the ScanGauge set to KPH makes the data collection relatively easy - just watch the video and start timing as you hit the target speed (70kph?) and then pause it every 10s and note the speed.
