I am guessing it's the same engine as a CVT model, but then you need to swap the flywheel over. Which is fine, but is the crank the same? Maybe the CVT crank doesn't have the pilot hole for the 5 speed input shaft? These are the kinds of things I want to avoid ha ha.
![Snail](/forum/images/smilies/snail.gif)
