Old 09-05-2013, 01:29 AM   #12 (permalink)
spacemanspif
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
SL1 denotes SOHC engine. If you have a DOHC you have an SL2 unless someone swapped in a DOHC into you factory SOHC car. Have you run the VIN to know for sure what model you have? Different Racing <- VIN decoder.
The RPM at highway speeds will give a clue as to what version of the manual trans you have. Considering your MPGs I'm guessing you have a SOHC trans with the taller 4th and 5th gears (MP2). DOHCs run about 3000RPM at 70MPH with factory trans, My DOHC with SOHC manual trans runs ~2400RPM at 70MPH (haven't been at 70mph in so long I forget the actual rpm lol).
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
