Old 09-05-2013, 04:00 PM   #11 (permalink)
tony_2018
Originally Posted by 97-civic-ex View Post
an old thread I know, but I figured I'd reply to clear up a few things. The 99-00 civic HX is the ONLY platform that used an OBD2a harness. So the obd2b ecu of any kind will not mate on to that car. A complete obd2b harness from an ex would be the closest match.
You are correct BUT only if it was the standard 5spd 99-00 HX. Main reason why is because they decided to do an "all-in-one" design with the ecu. That was when they decided to upgraded the harness as well. From 96-98 the CVT model had a separate TCU to control the CVT. The 5spd harness remain obd2a through 99-00 I guess because they felt there would be no need for changes. I've done my research on the both manual and standard ecu's for the 99-00 and they are of different design. I've already found my harness and confirm exact pinouts for the egr control and egr valve to be the same for the obd2b pinouts for the d15b 3 stage vtec ecu and I'm running pretty darn good. For now I had to change it to a d16y7 ecu auto because the d16y8 ecu was throwing codes for the lock up solenoid, mismatch of tranny and ecu was confirmed to be the issue.
