Old 09-06-2013, 01:43 AM   #36 (permalink)
HypermilerAX
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Originally Posted by UltArc View Post
All I can think is different sources. But your numbers drive the point harder.
Yes for your underrated original Mini width. No for your underrated 2013 Civic width.
Originally Posted by niky View Post
That's a huge difference in size. The AX is smaller in many key dimensions than the cars competing in the segment below the Mirage in Asia. Aside from the bigger footprint, there's the extra 200cc of engine, the air-conditioning (the AX was only 640 kg without AC), power steering and other niceties that come standard on the Mirage.
I take your point but it would be interesting to compare the inner dimensions of the cars. You can have a wider car but no more space inside due to thicker doors and you can have a higher car but no more place above the head due to a higher seating position. The mirage would probably still be bigger but by less.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
