Old 09-06-2013, 11:53 PM   #15 (permalink)
Xist
HydroJim, your modifications are looking great! Did the conveyor belt material give you many problems? How much does the camera stick out? I would think that it would be smaller than any mirror folded-in.
I know there was a small discussion on your headlights. Have you considered shaping plastic around them? That should make it more aerodynamic without affecting visibility.
Has anyone on here built wheel skirts from conveyor belt material?
It should be easy enough to test a grill block, your intake looks so small that one piece of duct tape might cover it, but then again, I doubt that you would see much of an improvement.
Aside from
possibly a coolant heater or oil pan heater
it seems like you have already completed most of the goals that you set in your first post. Now what are you considering?
