Originally Posted by XYZ
Unfortunately, highways are designed for motor vehicle traffic, not for the protection of "critters".
I suggest that you lobby your local politicians to reduce the speed limit to an absurdly low number and have them post critter crossings every few hundred feet. Then will you be satisfied?...
You are correct in that highways are made for cars and not critters. One could get the speed limit reduced, or when visibility is reduced (such as at night when visibility is limited by the range of your headlights and the reflectivity of things in the night) one could slow down to a speed that lets you see and avoid things on the road. Or you could just plow on blissfully unaware of what is just out of view.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
